Edges Texture with Vray Plane / Infinity Plane
  • Edges Texture with Vray Plane / Infinity Plane
    Can someone explain if I'm doing something wrong, or whether these are just two elements of Vray that don't play well together?
    In sketchup - Vray ExtraTex element with Edges texture & a infinity plane in the scene - the infinity plane shows up in RGB as expected, but in the extratex element it just renders white, where all other elements render white edge on black.
    Similarly in 3DSMax, the plane renders as expected in Extratex element, jut with some unexpected isolines
    These seem, to be two slightly odd behavious, neither of which is totally as expected (although I can kind of understand the extra lines in 3DSMax tbf)
    The first two are my sketchup scene and the 2nd two are my 3DSMax test scene
    Hi busseynova
    Could you please post a screenshot of the Edges texture setup?
    You could try adjusting the Background Color and Width parameters of the Edges texture to see if the desired results are achieved
