I'm rendering an animation, in order to actually be able to animate it i had to export frame by frame as SketchUp scenes, going through each scene the frames are correct. so next is Batch rendering it... which constantly crashes.
When? after clicking the batch render icon, it seems v-ray goes through every single scene and stores data of it (my guess entirely) and by the time it reaches scene 20~ it crashes
Why? I assume its because its too much for SketchUp/V-ray/my computer? (RAM?). I assume its the method V-ray chooses to actually handle batches
What do I need? I need batch render to stop crashing, and if its because its going through every single frame before actually starting the render process... can I know why it does this? what can I do to make it stop crashing? is there a script so that it can manually go through one scene>Render>next scene>Render instead of jumping through all scenes before starting the render?
What I'm doing right now I'm having to tick "include in animation" and render in batches of 20... this project contains 1560 Scenes(Frames) so I have to do this every 20 scenes, untick the last 20 I did, and tick the next 20.
Rendering is no problem, its only the batch render. its not specific to this project. (I've had to do this with 3 other projects at less scenes).
I'm using a plugin to create these scenes, which again, if I'm able to render in batches of 20, its not the plugin's fault (its SketchUp's scenes anyways)
the V-ray .log is empty (\AppData\Roaming\Chaos Group\V-Ray for SketchUp)
I can play through the entire animation using SketchUp's animation tool without crashing
Appreciate any help!
