Laubwerk and V-ray 5 for Sketchup
  • Laubwerk and V-ray 5 for Sketchup
    New to all this. Why is this happening with Laubwerk and V-ray 5? Re-installed latest versions of both in SU 2019,2020,2021. Any help would be greatly appreciated. Click image for larger version
    Hi Michael
    The Laubwerk player is not yet compatible with V-ray 5.
    I have contacted them and they are working on the issue.
      What are laubwerk models like? Anygood?
      e: info@adriandenne.com
      w: www.adriandenne.com
        I have only used the free models supplied with the laubwerk player and found them very good to work with.
        I used the free trees in the attached image.
          Thank you for the info. Didn't want to dive into Laubwerk if this was an ongoing issue.
            Hi all,
            As of today, Laubwerk officially brings support for V-Ray 5: https://www.laubwerk.com/home/season...ray-5-support/. Make sure to download the latest update and give it a try. Do inform us if you encounter any issues.
            Nikoleta Garkova | chaos.com
              Originally posted by nikoleta.garkova View Post
              Hi all,
              Thank you for the news.. I download and try it, it works with interactive and final render, but there is nothing seen in geometry tab, and vray vision shows just a box.. I use win10 the latest uptade and sketchup 2019 with vray 5 hotfix 2..
              When i am in materyal or light section and click on a laubwerk tree, it stays on that section and it shows the proxy settings on the right panel, but geometry section is empty..
                To avoid seeing the proxies as cubes, please turn off the Enable Proxy LOD option from V-Ray Vision's settings. This could be improved in a future update: http://ftp.chaosgroup.com/support/sc...1_16-00-53.jpg
                  Thank you..
