problems with full screen on mac - vray 5
  • problems with full screen on mac - vray 5
    I'm trying to run vray 5 for sketchup on my mac but I'm having some problems working in fullscreen when I go to render and the frame buffer opens. So when I click to render the frame buffer pops up in a new fullscreen window next to sketchup (which is just as i want so i can slide between the 2) but for some reason when I go back to the sketchup window it's now totally blacked out, the tool palettes are there but everything else is totally black making everything totally unusable. The only way to get back to sketchup is to quit it from the dock..
    This is happening in both sketchup 2020 and 2021 in both Catalina and Big Sur, I've also tried the latest hotfix 2 released yesterday with same problem in all combinations. Also tried disabling all other extension just in case... I contacted support a few days ago but haven't heard anything yet..
    Also, not in fullscreen, if i go to minimise the frame buffer window (floating above the sketchup window), the sketchup window also disappears.. it's like their entangled!
    Is anyone having any similar problems or have any idea why this may be happening? Thanks
    Click image for larger version  Name:	Screenshot 2020-12-17 at 01.09.57.jpg Views:	0 Size:	360.7 KB ID:	1096176Click image for larger version  Name:	Screenshot 2020-12-17 at 01.10.03.jpg Views:	0 Size:	193.8 KB ID:	1096174Click image for larger version  Name:	Screenshot 2020-12-17 at 01.10.36.jpg Views:	0 Size:	35.1 KB ID:	1096173
    Hi wawmsey
    Regarding the full-screen issue you're experiencing - I am unable to reproduce this with V-Ray 5 latest hotfix/SketchUp 2020 on Catalina. Would it be possible to describe the steps leading to this - does it happen with absolutely every project?
    Could you forward us the V-Ray/neui logs so we can investigate? You can find them at ~/.ChaosGroup/V-Ray\ for\ SketchUp/VRayForSketchUp.log and ~/.ChaosGroup/V-Ray\ for\ SketchUp/vrayneui
    Regarding the other issue (when minimizing the V-Ray Frame Buffer window) we're aware of that and we will let you know when a fix is ready.
    Nikoleta Garkova | chaos.com
      Hi nikoleta.garkova , thanks for your response
      Yes it seems to happen with every project I've tried, although it did randomly work once, but not again since even on the same project..
      To recreate - open sketchup 2021 (or 2020), enter fullscreen(opens in a new space), click render - the frame buffer opens in a new space to the right of sketchup in mission control, go back to sketchup (either swipe across or via mission control), the model window is totally blacked out (as shown in the above pics).. can do a screen record if that helps?
      How should I send you the logs? it says i'm not allowed to upload files ending in '.log'
      *Also not in fullscreen mode - I'm surprised that you can't drag the frame buffer to a separate window also? although i guess this may be tied up with the minimising issue you mentioned?
      Thanks
        wawmsey
        Thanks for the details. To forward the necessary files, best might be to write an email to Chaos Support. You can contact us from the following contact form: https://www.chaosgroup.com/help/cont.../scene#options
          Just to give you an update that the issue on full-screen mode has been logged under SK-3168 in our internal bug-tracking system. We'll make sure to let you know when there are any news on the matter.
            Thanks, would it be helpful to send through the log files still?
              The issue is already identified and scheduled. There is no need for further info at this point. Appreciate the time you took to report it!
              Further improvements of the VFB window ordering (its apprarent pairing with the SketchUp window) are also planned.
              Kind regards,
              Peter
              Peter Chaushev
              Let's keep in touch
                that's great, thanks!
                  Hello, wawmsey,
                  I would like to let you know that the issue is fixed with the latest hotfix - V-Ray 6 for SketchUp, update 1.1 (download link - http://download.chaos.com). A new option - "Parent Frame Buffer" is implemented. It is located in Extensions / V-Ray / Preferences / Parent Frame Buffer. Disable the "Parent Frame Buffer" option to view the V-Ray Frame buffer window on a second display or to switch between the SketchUp and VFB windows with the Mission Control.
                  Please let us know if it works for you.
                  Kind regards,
                  Iva
                  Iva Mancheva
                  V-Ray for SketchUp | V-Ray for Rhino | QA
                  www.chaos.com
