I wanted to make you aware of various issues I am observing while working:
- Clipping of the Vray Asset Editor on a multiple monitor setup: Main: HD Ultrawide, Right: HD monitor, Left: 4k monitor. I had already reported this during the beta trial, but I am still getting clipping of the right side of the asset editor if I drag it to the 4k left monitor (again, this did not happen in previous vray versions).
- Once I engage the A/B/C/D vfb review tool, it is very hard to get it to go back to just A/B tools (without C/D), is there a way to code in an override for the various A/B tools in the drop down of this button.
- Light Gen: I was working with a 35x8= 280 variation light gen set up. I noticed that with with one of the generation options, when I would apply it and then change the Rotate H values, it would change the light and then if I would copy back in the original Rotate H value, it would not match the original light setup. I think it was actually changing it to the light gen option next in line (just to the right) within the grid of options. I tried multiple times to trouble-shoot but it kept doing it with this particular setup. I ended up going with a different light gen option, which was not having any issues. I wonder if this was the last sequential option of a particular hdri file and then when I modified the Rotate H, it somehow kicked it to the next sequential hdri file??? (Sorry I did not take very good notes on which option this was, I can send the light gen save file if you want it). On a side note, one nice option to integrate into the future would be to be able to subset your favorite selected light gen option from within the larger number of options generate. So instead of having to scroll back and forth from 280 or more options. You could subset 4 or 5 of those to easily toggle between. It would also be nice to be able to add specific user owned hdri's as well (I had previously mentioned in beta).
- As a follow-up, I still have a huge request to be able to auto generate, or manually load thumbnail previews of geometry and custom library geometry from within the Asset Editor. (also had mentioned in beta)
