Vray Vision contour error
  • Vray Vision contour error
    Hi, i am using win10 the latest uptade, sketchup 2019 an vray5 -1 the latest version.. When i add contour attribute to the material, it doesn't render correctly..
    Edit : While searching, i learned that, contour attribute only works with CPU render, GPU is not supported, may be it is the reason of not working on vision..
    Hello, kenancakir.
    Thank you for mentioning that.
    For now Contours are not supported in V-Ray Vision.
    I will add your inquiry to the wishlist in our system with VRT-423 number.
    Stay tuned.
    It could be visioned.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Hi kenancakir,
      GPU support for the Toon effects has also been requested many times.
      It actually has to be supported in V-Ray Core first before it makes it's way in V-Ray for SketchUp.
      I'll let you know if progress is made in that regard.
      Konstantin
