Asset editor
  • Asset editor
    When I first started using vr4su, there was the material library and then a bunch of starting point to create your own material (ie pbr). Since version 5 these seem to have disappeared. Where they removed or is this an issue with my install?
    No one has this issue?
      Hi patrick_anderson
      To clarify, it shouldn't be an issue with your install - PBR material specifically can no longer be created in V-Ray 5.
      The reason behind this is because it has been merged with the Generic/VRayMtl workflow. The Metalness parameter is located in the Reflections rollout.
      There is also a parameter called Surface Control that lets you switch between Glossiness and Roughness for Reflections and Refractions.
      You can find thorough information on why this decision was made along with some example screenshots in this forum post. Hope that helps!
      Nikoleta Garkova | chaos.com
        Many thanks!
