Vray renders have a feather/halo on them when imported to Paintshop pro.
  • Vray renders have a feather/halo on them when imported to Paintshop pro.
    I have set my render background as per this solution (https://forums.chaosgroup.com/forum/...nt-backgrounds).
    e.g.
    In VRAY the render looks great:
    But when I import it into Paintshop Pro and do a backfill of black it has a transparent edge, which is not what is needed.
    (I do have pictures of all of this, but when I try to upload them I get the following message: Missing PHP temporary folder; check upload_tmp_dir)
    Hi rusty_badge,
    The people responsible for the forums have been notified and hopefully the problem will get resolved soon.
    As for your rendering issue:
    If you have rendered upon a black background in V-Ray, there should be no hallo effect in the post processing app.
    I'll have too take a look at the rendered image or your scene to help you further.
    Konstantin
      Settings:
      Render in Vray (no feathering)
      Showing Feathering
ID:	1111643Click image for larger version
        PS Konstantin thank you for replying.
          Hi rusty_badge,
          It is expected to see the hallo from the attached image in case you use something like a 'Paint Bucket' to fill the background.
          The reason is the aliasing at the alpha border. It is actually a good thing. Without it the alpha border will be pixelated.
          The proper way to do it is to create 2 image layers in the post processing app - the top one is your image, the bottom will act as a background.
          You then fill the bottom with the desired color:
          Konstantin
            Konstantin that was an easy fix. Thank you for taking the time as it just saved me days of stressing!
