Hi, first sorry for my english, second have problems when I want to make render with RTX option, im waiting one minute and Vray open windows then send me this report ( [VUtils::SimpleGPUBuffer::init] 2: Could not allocate buffer of size 4081MB!) and this ( Checking CUDA driver version: 5001: Installed driver version is newer than the latest verified one!) I have Nvidia RTX 3070, PLEASE HELP, THANKS
Nvidia RTX 3070 Problems with Vray
Hi, first sorry for my english, second have problems when I want to make render with RTX option, im waiting one minute and Vray open windows then send me this report ( [VUtils::SimpleGPUBuffer::init] 2: Could not allocate buffer of size 4081MB!) and this ( Checking CUDA driver version: 5001: Installed driver version is newer than the latest verified one!) I have Nvidia RTX 3070, PLEASE HELP, THANKSTags: None
Hi david_aguilarfigueras ,
Do you see this error with any scene you try to render?
If it's scene specific, then sharing the project will help us find the issue.
Another thing that I'd recommend is trying CUDA.
The warning that states your driver is newer can be ignored in most cases.
We basically have a recommended driver version.
Everything newer will cause it to appear.
Konstantin
I have a gtx 3090 and I usually use rtx to render. I just upgraded to the latest build and selected rtx and expected to wait for a bit whil it did it's compiling. It just started rendering via cpu.
Is there a specific nvidia driver you recommend and I take it you prefer us to use cuda?
I can send the scene if need be. I've got to get this job off my desk as soon as I can.
Hi patrick_anderson,
Note that the CUDA mode is by default utilizing your CPU together with the GPU/s.
This might have resulted in the shorter render time.
As for recommended drivers I'd suggest you visit our official GPU webpage:
https://www.chaosgroup.com/vray-gpu
There is a black band stretching across that shows the currently recommended version.
As of now it states:
Recommended NVIDIA driver for V-Ray GPU is version 471.11
