[Ruby API] Instancer scaling up during animation
  • [Ruby API] Instancer scaling up during animation
    In Skatter, we use an Instancer V-Ray plugin to export "Render only" Skatter setups to V-Ray.
    It works fine, except in animations. Instances duplicated via an Instancer plugin double in size at each new frame.
    Our code is not called after the initial on_model_exported event, so I'm guessing this is an issue in V-Ray itself.
    How to reproduce:
    - Create a Skatter setup, pick a Host and a Scattered Object, and enable "Render Only"
    - Create two SketchUp scenes
    - Enable Animation in V-Ray
    - Render
    I attached an example .skp showacsing the issue. You need to have Skatter v1 installed, and simply start a render.
    Can someone at Chaos please tell me if you have registered this issue in your internal bug tracking system?
      Hello, Thomas,
      Apologies for the late reply!
      The issue is logged in our internal tracking system (priority set to 'high').
      A solution is pending. We will keep you updated on its progress.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        Great, thanks!
          Hi jiminy-billy-bob ,
          The animation issue that you're experiencing can actually be resolved completely on your side.
          I assume that the instances property of the Instancer plugin is exported with the following data in your case:
          Instancer InstancerName {
          instances=List(
          0,
          List(1, TransformHex("D8B..."), Transform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0)), SU|44|29827),
          List(2, TransformHex("5DB..."), Transform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0)), SU|44|29827),
          List(3, TransformHex("130..."), Transform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0)), SU|44|29827),
          List(4, TransformHex("5BB..."), Transform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0)), SU|44|29827)
          The second transform for each of the items is its velocity transform and for static instances should be using a zero matrix instead of an identity one.
          The correct way to set the velocity transform:
          instances=List(
          0,
          List(1, TransformHex("D8B..."), Transform(Matrix(Vector(0, 0, 0), Vector(0, 0, 0), Vector(0, 0, 0)), Vector(0, 0, 0)), SU|44|29827),
          List(2, TransformHex("5DB..."), Transform(Matrix(Vector(0, 0, 0), Vector(0, 0, 0), Vector(0, 0, 0)), Vector(0, 0, 0)), SU|44|29827),
          List(3, TransformHex("130..."), Transform(Matrix(Vector(0, 0, 0), Vector(0, 0, 0), Vector(0, 0, 0)), Vector(0, 0, 0)), SU|44|29827),
          List(4, TransformHex("5BB..."), Transform(Matrix(Vector(0, 0, 0), Vector(0, 0, 0), Vector(0, 0, 0)), Vector(0, 0, 0)), SU|44|29827)
          This should resolve the animation issue.
          Regards,
          Konstantin
            Hi Konstantin,
            I am still experiencing the issue. I cannot find the velocity Transform menu in my Vray window. The only plugin I am using is Skatter before beginning my render, I am using Sketch up 2019
            Dom
              Indeed it does!
              I never thought an identity matrix would transform the instances, but I guess it can make sense depending on the implementation.
              Thanks a lot, this is resolved!
                  Does this happen to you using the latest version of Skatter?
