V ray render square stain
  • V ray render square stain
    Hi
    can someone solve this problem with rendering square stain?
    problem exist if i use swarn. If i render from my PC i dont have stains.
    Stains only shows while i render with swarn.
    Hello, mate_gada .
    This is most likely due to a reflection texture file that has not been transferred successfully to the machine assisting in the render process.
    To amend this, first, open the File Path Editor (Extensions > V-Ray > File Path Editor) to see if there are any missing assets or whether their location is inaccessible to the other machine.
    Secondly, look into the V-Ray Swarm log of the affected machine. Simply type http://[IP_ADDRESS]:24267/log (substitute IP_ADDRESS with the actual IP address of the machine). The errors/warnings there will point you to the exact file that is missing.
    If you are not able to determine which machine is rendering the faulty buckets, set up a "DR Bucket" render element and run another render. The moment you spot this discrepancy, stop the process and check the DR_Bucket render channel in the VFB. Each bucket will be tagged with the name of the machine that rendered it.
    Please let me know if this helps!
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
