IR Not recognizing Tag Folder State
  • IR Not recognizing Tag Folder State
    When using Interactive Render and clicking a saved Scene tab, VRay IR doesn't seem to recognize the tags in that folder as off in that scene.
    Matthew Valero, ASAI
    Hi ValeroStudio,
    Seems to be working properly in a quick test, please check the recording - http://ftp.chaosgroup.com/support/sc...3_13-35-29.mp4
    Let us know if we're missing something, even better - do share a recording on your end which we could use to try and set up a scene to reproduce. Thanks!
    Nikoleta Garkova | chaos.com
      Originally posted by nikoleta.garkova View Post
      Hi ValeroStudio,
      Apologies for my delay on getting back to you. So I just ran another test and this is what I have come up with. I have this model that has a few reference layers (a Revit model imported, CAD files and a flat site reference). These tags are all set to off in the 2 scene tabs I have setup and show at the start of this video. I also have some layers that have Cosmos components on them and some are off as well since I wanted 2D people in this render and not 3D.
      In the video link below, you'll see when I click the Scene tab for Study View A at 1:03, you can see Interactive Render going and then loading some of the tagged items that were off. Then at 1:40 my site aerial reference layer shows up even though it should be off in both scenes. Then at 2:16 the layer containing a few 3D Cosmos people characters turns on causing a slow down for those items to be loaded, even though that tag is off in the scene tab. At 2:42 a reference CAD section turns on. At 2:45 a reference import of a Revit model turns on. All of these items are bogging down the interactive layer and are unnecessarily being turned on, just to be turned off at 3:25.
      https://youtu.be/UPMFct7Wr_M
        Hi ValeroStudio,
        Since this looks much more complex, would it be possible to send us an example project so we can see if we're able to replicate it in our environment?
        You can submit it via our contact form, just make sure to mention this thread or my name in the form subject. Much appreciated!
          Hi ValeroStudio,
          Just sent that file over.
