Corrections only applied to EffectsResult, not to Denoiser or RGB output
  • Corrections only applied to EffectsResult, not to Denoiser or RGB output
    While testing V-ray 5 on Sketchup 2021 I noticed that the corrections in the VFB (Curves, Exposure, White Balance) only are only being applied to .EffectsResult.png and not to RGB or Denoiser output file while Saving to image channels to separate files. That didn't happen in V-ray Next. I mostly use EffectsResult for Glare and Bloom and still had control over Denoiser opacity in Photoshop with the corrections pre-defined in VFB.
    Is there any new workflow or some trick I should pull to ba able to do that like in previous version of V-ray?
    Hey Areczan,
    Indeed, this had a lengthy discussion in the following forum thread. As a result, we've placed an improvement request to save corrections to the elements as well. Stay tuned - we'll let you know when we have an update on the matter.
    Nikoleta Garkova | chaos.com
