Sketchup 2021 crashes after installing vray 5 update 2
  • Sketchup 2021 crashes after installing vray 5 update 2
    Sketchup crashes shortly after beginning to load addons, etc. When I remove vray, it loads and works as expected. I reinstalled the update 1 version and Sketchup began working again.
    I tried excluding swarm and cloud from the install, but got the same problem when starting Sketchup.
    I'm on Windows 10 (latest version as of 11/4/21) with an nvdia rtx 3080 and 32gb RAM.
    Hi Brett
    I'm having the same problems vray gpu takes a Lot of vram, i'm using update 2 i think the same i'm going to return to update 1
      Hey guys,
      Have you tried disabling any other 3rd party-plugins and loading V-Ray instead? We would need to find the culprit - if possible, do get in touch via our contact form so we can schedule a remote session and investigate on the spot. Please also mention this thread (or my name) in the form subject. Thanks!
      Nikoleta Garkova | chaos.com
        Good morning from the East coast of the USA. I've spent an hour going through ALLLLLLL of my plugins (chunks at a time, not one by one ;-\ ). Here's the culprit in my case: ky_Group_PushPull_2DFaces v0.4 %28gvar%29.rb (I hadn't even remembered it was installed and haven't actively used it in quite some time)
        To show what WAS NOT one of the problem scripts, I'm including all the scripts/plugins that I have installed, to shorten the hunt for others having load issues by potentially excluding these from their list. See below.
        Cheers,
        Brett.
        !!Fredo6_LordOfTheToolbars
        !!Fredo6_LordOfTheToolbars.rb
        1001bit_freeware
        1001bit_freeware.rb
        3dbazaar
        3dbazaar.rb
        AddVertex+.rb
        ams_FixIt.rb
        bezierspline
        bezierspline.rb
        cleanup.rb
        clf_loose_to_groups
        clf_loose_to_groups.rb
        curic_face_knife
        curic_face_knife.rb
        curic_la
        curic_la.rb
        curic_mirror
        curic_mirror.rb
        curic_space
        curic_space.rb
        DM_artisan
        DM_artisan.rb
        DM_BoolTools
        DM_BoolTools.rb
        DM_ProfileBuilder3
        DM_ProfileBuilder3.rb
        DM_SketchUV
        DM_SketchUV.rb
        dp_flat_text
        dp_flat_text.rb
        f3d_flextools
        f3d_flextools.rb
        face2group.rb!
        Fredo6_!LibFredo6
        Fredo6_!LibFredo6.rb
        Fredo6_Curviloft
        Fredo6_Curviloft.rb
        Fredo6_FredoTools
        Fredo6_FredoTools.rb
        Fredo6_JointPushPull
        Fredo6_JointPushPull.rb
        Fredo6_RoundCorner
        Fredo6_RoundCorner.rb
        Fredo6_ToolsOnSurface
        Fredo6_ToolsOnSurface.rb
        Fredo6_TopoShaper
        Fredo6_TopoShaper.rb
        InstantCladding
        InstantCladding.rb
        InstantRoofNui
        InstantRoofNui.rb
        InstantSiteGraderNui
        InstantSiteGraderNui.rb
        MAJ_Wall
        MAJ_Wall.rb
        Mirror
        Mirror.rb
        PDFImport
        PDFImport.rb
        Projection
        projection_extension.rb
        RandomSelect.rb!
        skatter
        skatter.rb
        SketchUcation
        SketchUcation.rb
        smustard_Weld
        smustard_Weld.rb
        SoapSkinBubble
        SoapSkinBubble.rb
        SplitUp
        SplitUp.rb!
        su_advancedcameratools
        su_advancedcameratools.rb
        su_dynamiccomponents
        su_dynamiccomponents.rb
        su_sandbox
        su_sandbox.rb
        su_trimble_connect
        su_trimble_connect.rb
        t2h_stretch_by_area
        t2h_stretch_by_area.rb
        TextureRandomizer.rb
        TIG-splitdonut
        TIG-splitdonut.rb
        TIG-splitsausage
        TIG-splitsausage.rb
        TIG-splitTOOLS
        TIG-splitTOOLS.rb
        transmutr
        transmutr.rb
        tt_architect_tools
        tt_architect_tools.rb
        tt_cleanup
        tt_cleanup.rb
        tt_edgetools
        tt_edgetools.rb
        tt_groups2comps
        tt_groups2comps.rb
        TT_Lib2
        TT_Lib2.rb
        TT_QuadFaceTools
        TT_QuadFaceTools.rb
        tt_replacer
        tt_replacer.rb
        tt_selection_memory
        tt_selection_memory.rb
        tt_selection_toys
        tt_selection_toys.rb
        tt_select_curve
        tt_select_curve.rb
        tt_solid_inspector2
        tt_solid_inspector2.rb
        tt_superglue
        tt_superglue.rb
        tt_truebend
        tt_truebend.rb
        ValiArchitectsUtils
          Hello, Brett,
          Thank you for the effort you've put in identifying the problematic plugin!
          Considering the .rb file is over 10 years old I am skeptical its author will fix its conflict with V-Ray.
          I'll pass the info to our dev team. They will see if the plugin conflict can be avoided on our side.
          I am sorry you've had such a bumpy first experience with the new Update 2. Hope this first impression changes as times goes and that you find the improvements we've made useful to your work with SketchUp.
          Once again, sincere thanks for the time you took to single out the incompatible extension!
          Kind regards,
          Peter
          Peter Chaushev
          V-Ray for SketchUp | V-Ray for Rhino | Product Owner
          www.chaos.com
            Thanks Peter,
            I don't even remember that plugin being installed... it's a hanger-on from copying .rb files from version to version to avoid reinstalling everything over and over, I suspect.
            I'm looking forward to playing with the new capabilities!
            Thanks,
            Brett.
              Hello, Luis,
              Is the memory usage increased for the same scenes with v5.20.01 when compared to v.5.10.06?
              You can check the memory usage from the "Stats" tab of the VFB's right-side panel or alternatively from the render log.
              If there is a discrepancy, please pack one of the scenes with increased memory usage (Extensions > V-Ray > Pack Project) and share it with us for further investigation via https://support.chaos.com/hc/en-us/requests/new
              Kind regards,
              Peter
              Peter Chaushev
              www.chaos.com
                Hello again, luisgamino2 ,
                We have identified the cause of your problem and hope to resolve it as soon as possible.
                Kind regards,
                Peter
                Peter Chaushev
                www.chaos.com
                  Hi Peter
                  In My tests vray 5.2 gpu is taking more vram than update 5.1, and is taking more than 1 GB is not few vram is taking a Lot, let me explain You what i see in this update, My scenes that worked with update 1 didnt work with update 2, same scene, same camara and the same settings, when i click on production render this is what happens... Everything is ok, loading the dome light, then loading proxis, then building and compacting optix, then start loading textures, when vray gpu finished loading textures and says aceleration building for optix 0 something like that says and then start light cache ( this is normal behaviur) with update 1, but when i used update 2 all this happened but with a surprise, when vray gpu finished loading textures or bitmaps and is almost ready to build the light cache then vray 5.2 takes a new bunch of vram.
                  Update 1 it says building aceleration 0 it takes 9.2 o 9.3 of vram and then start to building light cache but it doesnt take more vram, just build the light cache, when light cache is finished vray gpu starts to render and take a little bit of vram My gpu z says or the task manager says 10.4 or 10.5 and start to render, but with update 2 when is almost finishing loading textures or bitmaps and says building aceleration 0 and is almost to start light cache, then crashes so heavy, because from 9.3 or 9.4 jump something to 10.8 or something like that, Even before to start to render, and even before to start light cache, it takes the same with update 1 and 2 until light cache appears, and when light cache is almost kicking in the render with update 2 jump from 9.2 or 9.3 to 10.8 or something similar before start rendering vray, with update 1 is very diferent before starts light cache says 9.0 or 9.1 then when is almost ready to start light cache goes to 9.4 or 9.5 vram and build light cache, when light cache is finished vray gpu update 1 start to render and goes up again vram something like 10.4 or 10.5 but renders fine, no single problem.
                  Update 2 for vray gpu takes too much vram, Even too much before kicks in light cache.
                  I really hope that this is going to be resolved because i really want to try the new features, but i have to work right now and is imposible to render with update 2, thanks again Peter and Muhhamed for taking your time looking for these problems
                  Thanks
                  Best regards
