VRAY / Ketchup install problems on MACBOOK
  • VRAY / Ketchup install problems on MACBOOK
    Hi there,
    I installed vray for sketchup on my MacBook Pro Mac OS 11.3.1. When I start sketchup after installing vray, vray doesn't start, it shows this message: how could I fix this?
    Fehler beim Laden der Datei /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb
    Error: #<Errno::EACCES: Permission denied @ rb_sysopen - /Users/ozgurdemirhan/.ChaosGroup/V-Ray for SketchUp/VRayForSketchUp.log>
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `initialize'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `open'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `<module:Logger>'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:3:in `<module:VRay>'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:1:in `block in <top (required)>'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `eval'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `require_crypt'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `block in <top (required)>'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `eval'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `require_crypt'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `block in <top (required)>'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/eula.rb:48:in `ensure_accepted'
    /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:36:in `<top (required)>'
    /Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
    /Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
    /Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `register_extension'
    /Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `<module:VRay>'
    /Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:4:in `<top (required)>'
    Hi OD53,
    Would it be possible to get in touch with our Tech Support so they can assist you with the issue you're having? Please submit a request via our contact form, and make sure to mention this thread in the email. Thanks!
    Nikoleta Garkova | chaos.com
      If anyone else experiences the same issue on macOS with the v5.20.01 update, please follow this workaround guide:
      vray_sketchup_52001_permissions_guide.pdf
      The issue will be resolved in an upcoming hotfix (v5.20.02).
      Peter Chaushev
      Let's keep in touch
        Peter.Chaushev Wow , it did work !!!!! Thank you very much!
          Hello, im a spanish user of SKP Pro 2021 in a Mac Catalina and i hace the same problem.
          Error al cargar archivo /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb
          Error: #<Errno::EACCES: Permission denied @ rb_sysopen - /Users/antonioperezdecastro/.ChaosGroup/V-Ray for SketchUp/VRayForSketchUp.log>
            I tried the vray_sketchup_52001_permissions_guide.pdf but it still does not work.
            Any more ideas?
            Thanks
              Hello, antonio_perezdecastro ,
              Please use the following installer: https://nightlies.chaosgroup.com/#/v...table/20211112
              It contains a fix to your problem.
              If the issue persists even with this temporary build, please reach out to our support team for direct assistance!
              Kind regards,
              Peter
              Peter Chaushev
              Let's keep in touch
