Only VFB Window in Bright theme
  • Only VFB Window in Bright theme
    I have a little problem.
    On one file only, the VFB window appears in Bright Mode while the Asset Editor window is in Dark Mode.
    How can I switch the VFB window back to Dark Mode ?
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
    It's work now !
    I switched to the Bright Theme. I closed and restarted Sketchup. Then I switched back to the Dark Theme. I closed and restarted Sketchup again and it works.
    Do you know of this "bug"?
    Chaos Vantage 2.7.1
      Hi DCHA34,
      Originally posted by DCHA34 View Post
      It's work now !
      This is a bug.
      The VFB doesn't have a bright theme.
      This issue has happened to me once also but I can't find a reliable way to reproduce it.
      Please keep an eye for this and if you find the actions that cause it, please let us know.
      Konstantin
