2d Displasement issue
  • 2d Displasement issue
    Hello, when I render a sphere using 2d Displacement and Cuda, the render result is unsmooth!
Name:	test-2d displasement.jpg
    Hello,
    This is most likely due to the smoothing of the sphere on which the Displacement is applied.
    Try to select the surfaces then right-click then select soften/smooth edges to see if it will make a difference.
      The sphere is smooth, kindly check the attached skp file.
        Hi rami_atef,
        Thank you for sharing the scene.
        The issue is reproducible and has something to do with the way we're exporting the geometry normals.
        I'll log a ticket for this and we'll investigate further.
        Konstantin
          Great to know, thank you!
