Missing materials during import DAE
  • Missing materials during import DAE
    Hello to all,
    when I import a DAE file (from Blender, I only have this software to test) the materials are present in the Materials tab of Sketchup, but they are absent from the Materials tab of the Asset Editor.
    I have to save the file, close it and reopen it so that the materials appear in the Asset Editor.
    Known problem?
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
    bug or not ?
    Chaos Vantage 2.7.1
      Once i had that problem, create a new material in vray, or drag any vray library materials to the list, missing materials will come.. I hope..
        Thanks for the tip. I will try that.
        So it seems to be a bug, if it happens to you too.
        Chaos Vantage 2.7.1
          Hi guys,
          Known problem?
          The described behavior is unfortunately the expected one.
          V-Ray relies on something called "observers" in SketchUp to know that the model has changed somehow.
          After we detect a change we can execute some V-Ray side code to handle the change - like adding a new material.
          Unfortunately for some of these import operations the SketchUp observers don't fire and there is no way for V-Ray to react.
          From V-Ray's standpoint nothing in the model has changed.
          We will gen in touch with Trimble and se if they can make a fix on the SketchUp side.
          In the meantime you'll have to work around it.
          Note that if you import the file before V-Ray is activated in the model (before clicking any of the V-Ray toolbar buttons) you'll see the materials in the Asset Editor after you activate.
          Regards,
          Konstantin
