When I'm using SketchUp vray5.2, click rendering always makes a mistake that I can only use 5.1
5.2 rendering error
Hi cq_x,
I'm very sorry to hear about your negative experience with the latest V-Ray version.
Please answer the following questions to help us understand what's going on:- Does the error only occur when rendering specific projects? If so, please share one of the projects that produce it for further testing on our side.
- Can you show and use the Asset Editor before you start a render?
- Do you have any other 3rd party extensions installed? Can you try disabling them and see if that makes a difference?
- Please share your system specifications and the rendering mode you've selected? Are you trying to render on the CPU or on the GPU (CUDA / RTX)?
Konstantin
I'll post a translation of your answers as a reference:
Hello, thank you for the reply.
Question 1: I tested with a file originally saved with version 5.1...
Question 2: I can open and use the Asset Editor before rendering.
Question 3: I have not installed any other third-party extensions or plugins that could affect the rendering.
Question 4: Windows 10; SketchUp 2021.
It is not currently possible for me to share the test files.
Regards,
Konstantin
