Vray gpu is repeating noise treshold
  • Vray gpu is repeating noise treshold
    What's going in on??? Impossible to finish a render!!! Is taking hours because repeat a Lot of noise... Buckets takes forever and progressive is the same why is repeating a Lot of noise and these keeps repeating this is happening with 5.1 vray gpu, this software is just full of Bugs!!! I'm not going to support more if chaos grouo keeps offering this trash of software, don't bring new shaders, just make this software works as it should be!!!
    Hello, Luis,
    I am sorry to hear your work has been obstructed by further V-Ray GPU issues!
    The message duplication is reproducible only with v5.10.01. Nevertheless, it does not have any actual impact on the render process. It is fixed in later v5.1 builds, e.g. v5.10.06.
    Is the slowdown you described reproducible only with a specific scene and/or settings? Did it occur with v5.2?
    Submitting a scene for investigation via https://support.chaos.com/hc/en-us/requests/new can help my colleagues identify and solve this problem.
    Please let me know if you are comfortable with receiving direct remote assistance that will allow us to help out in the shortest timeframe possible and determine whether there is something specific with your setup that generates this unusual amount of issues with the GPU engine.
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
      Hi Peter
      I was using vray gpu 5.1 hotfix 5 the latest and this is happening every day when i do a render...
      Can You please share an example how really light cache works with gpu, probably with 3d max since update 2 for sketchup and rhyno was a really disaster... It is impossible to use, i really hope You find a solutions to this problem.
      What is going to happen with ipr??? Is it going to work Nice with gpu light cache... For production didnt work, and for ipr i think is the same.
      Also the UI is the same than update 1, for example buckets región is not working why this parámeter remains Even if it doesnt work, take it off.
      Also light cache appears black when it is going to start, impossible to see anything until vray gpu starts rendering
      Also sss effects are working Nice??? How those option works right now with gpu light cache... So many questions!!!
      Thanks
