Decals Material_ID problem
  • Decals Material_ID problem
    Hello to all,
    I don't know if the problem has already been mentioned but I'm having a problem on the Material_ID channel with the "Decal" object.
    What is this white border on CPU Render ?
    Pictures are better than words.
ID:	1140318Click image for larger version
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Can you please share an example? Seems I can't reproduce this on my end.
      Here is the file. :
      https://ufile.io/ybwjya71
      Chaos Vantage 2.8
        Thank you!
        I have logged the issue under SK-3798.
        As a workaround please use the mask in the Decal here
Name:	Screenshot 2022-02-18 at 10.01.07.png
        Instead of the Diffuse Texture Alpha option
Name:	Screenshot 2022-02-18 at 10.02.48.png
          Thanks for the workaround. But the patch will be welcome.
          Chaos Vantage 2.8
            Hello DCHA34 !
            I would like to let you know that the described issue, causing the incorrect "Material ID Color" Render element in CPU when the "Diffuse Texture Alpha" option is enabled, is resolved in our V-Ray 6 for SketchUp versions.
            Regards,
            Ivelina​
            Ivelina Mincheva
            V-Ray for SketchUp | V-Ray for Rhino | QA
            www.chaos.com
