Mesh surface preview while rendering with glass material
  • Mesh surface preview while rendering with glass material
    Does anybody know how i can smoothen the material and see no mesh surfaces in the render for glass material?
    Hi shinu_thomas,
    If this is a regular mesh you should be able to smooth it with the Soften Edges feature in SketchUp.
    If however it is a V-Ray proxy, you'll have to smooth the original mesh and the reexport it.
    It is also possible that the problem lies elsewhere.
    There might be overlapping faces causing similar artifacts.
    The bottom line is you have to inspect the mesh object and ensure it's clean and that its normals are smoothed.
    If nothing helps, please share the model for inspection on our side.
    Konstantin
