Error Rectangle Light
  • Error Rectangle Light
    I noticed in the last update (5.20.06) an error where the light rectangle is circular by default, even choosing rectangular.
    Hello henriqueb,
    Do you have Directionality enabled? Also, does this also happen in a new project?
    Can you send us a simple test scene where the issue is reproducible so we can have a look? When testing on my end I was not able to reproduce it.
    Thank you.
    Aleksandar Kasabov
    chaos.com
      Hello, @aleksandar.kasabov the error happens when using light intensity lower than 30. I work with the unit in watts. There was never this before. with the value 10 or 5 the light rectangle already shows the problem.
          Hello henriqueb,
          Thank you for sharing those details with us.
          I tried reproducing this issue on my end (with the info you have provided) but I was not able to. Would you mind sharing a simple test scene where the issue is reproducible?
          Thank you.
          Aleksandar Kasabov
          chaos.com
