RGB Channel Issue
  • RGB Channel Issue
    I use windows 10 and vray 5 latest uptades.. When i render with vray denoiser RGB channel also looks like denoised image, not without denoiser..
    I know i can turn denoiser off in framebuffer, but If denoiser on, i thought efects resaults channel will show..
      Dear kenancakir, hello.
      I will explain the details now.
      You have properly noticed that Denoiser could be turned ON/OFF in the V-Ray Frame Buffer (by clicking over the eye icon), but the difference when doing it will be seen in RGB color channel only.
      This provides you a fast check between the denoised and undenoised result. WIth one-click it is easier to compare.
      If you save the render by choosing Save all image channels to separate files or Save all image channels to single file you will see that RGB will be undenoised and effectsResult will contain the Denoiser pass.
      Hope this will bring more clarity.
      TS
      Tsvetomira Girginova | chaos.com
      3D Support (AEC,HOU,C4D) Team Lead | contact us
        Thank you..
