The grass models in cosmos, why don't they have two sided materials, which we normally use for foliage. It's an issue I've been facing in sketchup, when trying to set a scatter with cosmos grass, I couldn't place the sun opposite to the camera, because the grasses won't let sunlight to penetrate through, resulting in a thick dark green patch. One solution is to create a new two sided mat. and merge the cosmos asset and assign new material. Is this a bug or is that the way its created?
This test render shows that difference. Left image with manually created two sided mat. Right image, default cosmos asset.
