It's my first time using Vray and I'm struggling with finding out why my chaos cosmo objects aren't rendering through my windows. They render fine when there isn't a window, so I'm assuming the window it the problem.
Chaos Cosmo objects aren't rendering through windows
Hello Kate,
Thank you for your question!
Could you please make a screenshot of the same view in SketchUp and make sure that trees can be seen from this angle through the window.
Also you can try changing the material of the glass to Glass Crystal material from Chaos Cosmos Browser. And please check if the glass model is a one-sided object or not, use Push\Pull if needed to create a thick glass. For reflective and refractive materials it is important that objects have some depth as in the real world, otherwise it can lead to some issues and incorrect renders. Please see the attached example.
If none of the above helps, please send us a scene to investigate. You can do this by packing your project using the SketchUp menu Extensions > V-Ray > Pack Project and then share the resulting archive via https://support.chaos.com/hc/en-us/requests/new.
