Bump Edge map not working VRAY for sketch up
  • Bump Edge map not working VRAY for sketch up
    Hello guys,
    I am having few troubles with rendering smooth edge applying bump edge map to material in Vray for sketch up. (i follow the document online but it doesn t solve my issue )
    I attached screenshot of the setting and result I am getting. (i already played around with increasing and lowering the width value without any result )
    I know that the two solid element are touching, but ideally I would like to use this effect in every materials to always create a small shadow gap and make the render more realistic
    Can someone help me, it is driving me mad ?
    Thank everyone !​
    try with Local Space Bump mode.
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
      Looks like it is working now ! thank you very much. I will try later on a much more complex model. Finger crossed.
