SU: two point perspective or perspective, field of view 35 degree. Vray: 16:9 or match view port. All with simular result, and not the same view in vray render as in Sketchup viewport. What am I missing here ? In attache especially visible round center colum (fireplace not in render)
Field of view in render versus Sketchup
This doesn't look like a field of view issue you are having, as those seem to match.
Your problem seems to be refraction from the glass. Are your windows a single surface with refraction turned on? If so, you should either make your windows have thickness with two surfaces to get correct refraction or check the thin-walled checkbox in the material's refraction properties.Last edited by shelshok; 22-12-2022, 04:22 AM.
