bonjour souci de rendu qui persiste je ne comprend pa
bonjours probleme au rendu cuda impossible
Hello jonathan_florentincvdh
Please note that we are able to provide support only in English. Additionally, I have moved the topic to the SketchUp section of the forum.
I would like to begin with a few questions, as they would allow us to understand the issue better:
- Please share with us the version of V-Ray you're using. You can find it in the Extensions > V-Ray > Help > About menu and a screenshot of the "About" window would be very helpful for this purpose. In addition to this, please include the SketchUp version as well (e.g. SketchUp 2022).
- Is this happening with every project (even newly created ones), or is it occuring only with this specific file?
- If you go to the V-Ray Asset Editor > Settings tab, what have you chosen in the "Quality" slider? Are you perhaps using "Medium+" and if you are, could you check if you are still getting the error with "Medium" or "High"?
- What is the model of your GPU and which version of the NVIDIA drivers are you currently using?
- Finally, how often does this error appear? Is it happening 100% of the time whenever you start a render and are you using the CUDA or RTX mode?
Thank you in advance!
Kind Regards,
Zahari
Thank you for the reply and for the additional information!
This may have been caused by a bug we have reproduced with Displacement set to Normal Displacement and CUDA renderer with CPU selected. This is logged in our bug-tracking system under SK-4133. If you get this error in any other scene with CUDA and Displacement this is most likely the cause and the possible workaround options are:- Set CUDA to GPU only.
- Or use CPU or RTX render engines.
