I am using Vray 6.00.02 for Sketchup 2022. This is my first real investigation into the Enmesh capabilities.
Basically I am trying to get an Enmesh host to "Sweep" or "FollowMe" around a corner so that the effect is a mitered corner look. See attached image. The goal is to minimize hassle and modeling time by not having to address each outside corner with modeling that geometry.
I've managed to create a regular shingle coursing effect which is assigned to a host that has a material assigned to it, which governs the coursing because my base mesh was crafted to match the coursing of the shingle image used in the material. The issue becomes when it reaches the corner. I've tried making a separate Enmesh that has a mitered corner base mesh which seems to work ok until I apply the material to it...then it disappears.
My hunch is I'm probably not understanding how the material governs the Enmesh.
Any help would be appreciated.
Thanks
Carl
Thanks
Carl
