no loop for bitmaps sequence texture
  • no loop for bitmaps sequence texture
    Hi there,
    I report here a iussue about the loop switch in the bitmap sequecence: it doesn' t work both in V-Ray and in Vantage. I attach you a screenshot of the setting of the bitmap sequence in a Color texture slot of an emissive material to simulate a burning fire using a sequence of images. As you can see from the attached Video when the sequence end it doesn't loop and a white emissive material without bitmap is visible in the animation.
    I wrote this post firstly in Vantage beta part and vladimir.nedev tested it also in V-Ray standalone.
    Ho wrote:
    Originally posted by vladimir.nedev
    So, I got access to SketchUp and tested this.
    It seems to be a problem with V-Ray for SketchUp, because if you render the exported .vrscene with V-Ray Standalone, you will get the same result.
    You should report it to our support or on the SketchUp part of our forum.
    So I report it in this part of forum.
    Cheers,
    Davide​
