Enmesh Question
  • Enmesh Question
    Hi there guys, just new to using enmesh and trying it with the cosmos assets. Just a quick question, if I have a grouped plane with material added then add the enmesh object it applies it correctly but the material reverts to default material. I have also tried adding the material to the enmesh object itself, then applied that to a new group, with the material on it as well and still no luck.
    Could anyone point me in the right direction? I have had it work once on a flat plane, but have had trouble ever since and I have been using the same method. Not sure what I am doing wrong. I have also attached a screenshot of what I mean, Thanks in advance, Nick
    Hi, try applying the material to the group, not the faces.
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
      Thanks mate - that worked, I thought that was what I was doing! Thanks heaps for the reply,
      Cheers, Nick
        As DCHA34 already mentioned, Enmesh only modifies the topology of objects it is applied on. Material assignment still comes from the base object, not the enmesh pattern distributed on it.
        Peter Chaushev
        Let's keep in touch
          Thanks Peter, much appreciated, Cheers, Nick
