Contour not in asset editor
This topic has been answered.
  • Contour not in asset editor
    Wanted to try contour for the first time in V-Ray 6.10............but hey - its not there at all !! As I understand it should be right under volumetric enviroment. Any ideas why its not there ?
  • Answer selected by natalia.gruzdova at 30-06-2023, 12:07 AM.
    Hello kimalbech,
    As DCHA34 have pointed out you have to look for Outlines (example) if you are using CPU render engine. Please note that for the GPU render engine this feature is not supported.
      Hi, maybe what you're looking for is called Outlines and can be found in the Settings tab.
      The option below Volumetric Environment.
      Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
      Sketchup PRO 25.0.571 + V-Ray 7.00.03
      3DS Max 2024.2.7 + V-Ray 6.20.06
      3DS Max 2025.3 + V-Ray 7.00.04
      Chaos Vantage 2.7.1
      GeForce Studio Ready Driver Version 572.16​
        Thanks - really weird - see screenshot - not there.........
          Only in CPU mode.
          Chaos Vantage 2.7.1
            Hello kimalbech,
            Natalia Gruzdova | chaos.com
              ahhhh - got it - thank you both one of these issues where your brain is locked in one direction, and you can not see whats around you
