Hi there can anyone please offer a solution as to why my render is displaying a blocking image?
Render blocked by shadow image
Hello trevor_groeneveld,
Thank you for the example.
Most likely wzfwzfwzf is right, please check out the documentation notes here:
- V-Ray Clipper works best with "closed" objects. The results on open objects (without a corresponding back face) are not well defined.
- Currently, the V-Ray Clipper may produce artifacts if there are overlapping triangles in the scene, regardless of whether they are part of the same object or not.
