Material ID and Render ID Passes Have Artifacts
This topic has been answered.
  • Material ID and Render ID Passes Have Artifacts
    I feel like something happened to the Random Material ID pass recently that made it contain a lot of artifacts. It used to be very clean and selection in PS was easy.
    Matthew Valero, ASAI
  • Answer selected by natalia.gruzdova at 04-09-2023, 03:12 AM.
    Solved. That’s the bug…me!!!! I never realized that JPEG created so much compression compared to PNG. Even copying layer to clipboard is cleaner than JPEG. Lesson learned. Thank you.
      Hello ValeroStudio,
      I have made a quick test between the versions and at a first glance there are no changes.
      What image file format are you using in this case? Artifacts from your screenshot look like .jpeg compression. If you indeed are using .jpeg please try to save your image and render elements as .png instead.
      Natalia Gruzdova | chaos.com
          Glad it is resolved! ​
