Hello, I am trying to render a bathroom project but there are some black lines appearing in the render on the bath tub (see attached images). Does anyone know whats causing it and how to resolve it? Thanks (Vray for Sketchup, latest version)
Black Lines appearing on curved surface (bath tub) - how to resolve?
Hello kristo_crushcov,
Thank you for your post.
You can try to change the material of the bathtub to test if material is causing the issue. If this does not help, most likely there is an issue with the geometry of this particular model. Is it a 3D Warehouse model?
Can you attach the bath here on forum (as .zip archive) or share a link to the original model so we could take a look?
Hi kristo_crushcov,
Are you trying to use Post Link option by any chance? You need to click on the Upload Attachment button, please see the screenshot below:
Last edited by DCHA34; 15-09-2023, 07:20 AM.Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
Sketchup PRO 24.0.553 + V-Ray 6.20.04
3DS Max 2024.2.3 + V-Ray 6.20.06
Chaos Vantage 2.4.0
GeForce Studio Ready Driver Version 546.01
- Likes 1
Thank you for the file.
Seems there were some issues with how the Component of that particular part was created. I have exploded and recreated it and it solved the issue. You can see the process in this video.
Also I am attaching the fixed model to this post just in case.
Hi everybody,
I just wanted to give you some more general information.
Artifacts similar to the ones in the original post point to overlapping geometry in 99% of cases.
The blackness is caused by self-shadowing of the overlapping faces.
There is something in the V-Ray options that can help called Secondary Ray Bias:
You should consider this option if fixing the geometry is not an option.
In all other cases - fixing the mesh is best.
Konstantin
- Likes 1
