Vray Pack Project Issue
  • Vray Pack Project Issue
    The other day, I had a coworker package up a project being worked on. They were able to do it, but the file extension for the zip was a .30 file, instead of a .zip. Is this a bug/issue with the pack project function?
    UPDATE: Nevermind, I figured out what was wrong. Our files in the office, typically have a date included in the filename (ex. 2023.10.31), so Vray interpreted it as that we wanted the file to have a .30 extension, rather than it tacking on the .zip at the end. I renamed the file to have the .zip extension, and it worked. I'll keep this in mind for the future.
    Thank you james_morvay1 for the update regarding your case! It is good to know you have found a solution and we appreciate you sharing it on forum.
    As an option you can name your files using underscore instead of dots (eg. 2023_10_31).
    Natalia Gruzdova | chaos.com
