Panorama/ Cube Map not working anymore
This topic has been answered.
  • Panorama/ Cube Map not working anymore
    Hi there,
    In a specific model when I try to render a spherical panorama or a spherical cube map it doesn't work anymore. I get a normal render instead. In other models it works just fine and it used to work just fine in the particular model as well.
    The only thing I can think of is that I've tried out Enscape with this model in the meantime. I've since disabled the extension for that.
    Is there anything I'm missing that forces the normal render?
    Thanks,
    Maarten
    p.s I can't share the model because of an NDA with the client.
  • Answer selected by natalia.gruzdova at 24-11-2023, 07:38 AM.
    To answer my own question: the camera was on two-point perspective.
        Hello maarten_vis,
        Thank you for the update and you are right regarding the two-point perspective. I will mark your answer as a solution
        Natalia Gruzdova | chaos.com
