Vantage Displacement
  • Vantage Displacement
    Am I missing something? I am using the displacement modifier but the result in Vantage is not working the same as in the engine within SketchUp. Seems to ignore Keep Continutity and the result is very jagged. Click image for larger version
Name:	Screenshot 2023-12-13 092111.png
    Matthew Valero, ASAI
    Hello, Matthew,
    There are two separate issues at hand here:
    • Displacement in Vantage appears incorrect when the displaced object in SketchUp has its material applied only to its group/component and not to its faces. (SK-4594)
      This can be worked around with a a couple of clicks by selecting the displaced object and using the V-Ray Tri-Planar Projection tool located in the V-Ray Utilities toolbar.
    • Displacement's "Keep Continuity" option is not yet fully supported in Vantage. (LAV-1713).
      No workaround for this one yet but it is already being solved by the Vantage dev team.
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
