grainy renders
  • grainy renders
    HI everyone , I do have heavy grainy renders. First everything was fine, but all of a sudden, Renders are very grainy, cannot figure out what is wrong. Also the saved images are very grainy
    Anyon for help. also noticed that in the saved folder, only two PNG are saved.
    Probably a rogue standard material. What happens when you do a material gray override?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      Hi bobby,
      found thé issue. I had a section Plane in my model. Don’t know why but by removing it. Everything went ok.
        You need to change the progressive to barrel rendering mode, make sure your engine combination is BF+LC, and turn on the denoising mode.
