Vray file path editor archive not working *copy failed"
  • Vray file path editor archive not working *copy failed"
    I'm trying to archive the textures of all the yellow state materials to a folder on my pc but when I click archive and select the folder (I tested 2 different folders) it errors and do not copy the textures.
    This is the error:
    > 1 errors occurred.
    > "C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui" copy failed.​
    I recently updated to latest version:
    Can someone please help?
    Thanks
    Hello, renata_digiogio,
    Thank you for you report!
    Unfortunately this is a known issue. We will let you know as soon as there is any progress on the matter.
    For the time being as a workaround you can save the textures manually via SketchUp "Export Texture Image" option (right click on the material in SketchUp Material panel's "In Model" section).
    Keep in mind that the files with yellow color mark are embedded in the SketchUp project and will not be lost when the file is opened on another machine.
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
