Vray Vision animation export issue
  • Vray Vision animation export issue
    I am using sketchup 2019 and the latest version of Vray 6 with microsoft 11, gpu rtx 4080.. I set two scenes with scene delay zero and transition ten sec. Animation was on in vray settings with medium plus and progressive with rtx choosen.. When i push play button it stays on the first scene entire animation, i thougt may be export works and i export as video and the same frame for entire ten seconds.. I thought may be rtx was the problem, i tried with cpu and non progressive but nothing changed.. Am i doing something wrong?
    Edit. Camera is set two point perspective.. I change it to perspective and it works now. I watched e few video about topic including chaos official video there was no mention about camera settings, or may be i missed it..
    Hello kenancakir,
    Thank you for your post.
    I was not able to replicate the issue with a Two-point perspective as you have described it.
    I have created test scenes with the latest V-Ray 6.20.02 version and SketchUp 2019 (also checked 2023) and both Image sequence and Video are rendering successfully. I made sure to replicate your animation settings as well - Scene delay = 0, Scene transition = 10 seconds. Therefore please note that Two-point perspective cameras can be rendered.
    Possibly there was an issue with SketchUp animation itself, you could try to delete Scenes and recreate them.
    Also I would like to point out that render engine and quality selection in V-Ray Asset Editor applies to V-Ray production animation, while Vision is a separate render engine that always renders with GPU and has its own settings for quality, resolution etc.
    Natalia Gruzdova | chaos.com
      Originally posted by natalia.gruzdova View Post
      Hello kenancakir,
      Hi
      Thank you. When i saw your answer i tried again and now it works with two point perspective. I am making tests on a scene, if something unexpected happens i will post under this topic.
