So dissapointed with the lack of features with vray gpu 5.1
  • So dissapointed with the lack of features with vray gpu 5.1
    Hi Konstantin
    Today i was triying to play with the options of omni light affect diffuse and affect speculars. (Vray gpu 5.1)
    By default it is 1, tried .5 or .75 does not work because does not have support for vray gpu while it works with vray cpu.
    Did vray gpu team already check that Konstantin???
    believe me some times vray gpu become really stressfull.
    A lot of features still does not work with vray gpu.
    It is like an engine with half features with vray gpu
    A lot of bugs.
    The other day i installed vray 6.2.3 and i finally could open my files.
    but then a Bug, i installed the correct driver, everything as it should be and i got a crash and a crash.
    I used the compresed textures mode, even with enought vram i could not render anything.
    It is like...What else i can do???
    Vray gpu 6 for me it was not an option
    Sorry to say that but this is the real truth.
    Vray gpu team is leaving a lot of nice features, so dissapointed with the lack of features with vray 5, with vray 6 i get a lot of bugs.
    I hope vray gpu team look at this, it is not the same vray and vray gpu
    Vray cpu 100% full features
    vray gpu, bugs and 50% or 60% of features that are usefull.
    Thanks
    I did some experiments and i found very usufull those options
ID:	1208651 This example is with default settings 1 for diffuse and specular
ID:	1208652 This example is with .5 in affect difusse and affect specular
    As you can see Konstantin the second example looks so much better.
    Finally understood why my lamps always does not look right, they always look burned out.
    This is an experiment with vray cpu
    Why this is happening?
    What else im going to find with vray gpu?
    I did a render with vray and vray gpu and the cpu option was so much better.
    Vray did a better job than vray gpu.
    Ahhhhh It is so stressfull.
    I found something to play...It does not work with vray gpu.
    Very dissapointed with the development of vray gpu, very dissapointed!!!
