Managing light gen lights with layers to batch render
  • Managing light gen lights with layers to batch render
    I have generated different light solutions for various rooms with light gen. They all use the same HDRI. I have put each light on a separate layer. Only the relevant layer is included in the saved scene but when I batch render the scenes, all the lights show in the Lightmix pallet of the VFB. Any ideas what I've done wrong?
    Hello greg_mathers,
    Welcome to Chaos Forums!
    What you describe should be working, just make sure to update each Scene.
    I have made a simple test scene with three Light Domes (using the same HDRI map, but different settings) and three Spheres. You can download it here to test (V-Ray version is the latest 6.20.04 build).
    Click image for larger version  Name:	Example.jpg Views:	0 Size:	237.8 KB ID:	1209749
    If you are having troubles setting up your scene please open a ticket using this submit request form and upload the archived scene in the ticket. Make sure to archive it with the Pack Project tool (Extensions>V-Ray>Pack Project tool).
    Also please share the exact V-Ray version you have currently installed (check About window V-Ray for SketchUp).​
    Natalia Gruzdova | chaos.com
      Thank you, Natalia. The error were indeed user generated.
        No problem, glad this is resolved!
        If you need our assistance do not hesitate to post here on forum or reach out to us in a ticket.
