V-ray Frame Buffer Issue on Mac
  • V-ray Frame Buffer Issue on Mac
    Hi everyone, I am using a Mac (SketchUp 2024 and V-Ray). After updating to SketchUp 2024, I have an issue with closing the V-Ray frame buffer. Has anyone experienced something like this? I will be waiting for your help. Thanks!
    Hello aliserdar_ozadam,
    Thank you for your post.
    I would like to share that there is indeed an issue with closing VFB on macOS SketchUp 2024 version. This is logged internally under SK-4889 and I have linked your forum post to it, so we will notify you of any changes.
    As for the workaround please try:
    • Open new empty SketchUp scene;
    • Go to Extensions>V-Ray>Preferences and disable Parent Frame Buffer;
    • Restart SketchUp;
    • In the new session Frame Buffer Parenting will be disabled and you should be able to close VFB.
    Let me know if this works for you as well.
    Natalia Gruzdova | chaos.com
      Hi Natalia,
      Yes, it worked for me. Thanks very much for your quick reply.
        Same issue. Found another, simpler work around. Click "Save" to save the image and then cancel out. Now you can close VRFB.
          Thank you for sharing your findings with us kbeck! I confirm that your workaround also works.
