Scatter how can I make sure that the objects do not go out of the edge of the surface
  • Scatter how can I make sure that the objects do not go out of the edge of the surface
ID:	1212966every time I insert objects on a scatter area I can't make sure that they do not go out of the edge of the area what should I select thanks​
    Offset the scatter area about 10 (app. the same size of the grass) cm, make it group and scatter the grass that fits in the area not rectangle grass, one tile one..
      Hello, alexpacio2015​.
      We implemented Edge Trimming option for Scatter that will be available in our next major V-Ray version.
      Another way to avoid the unwanted scattered guests for now is to use the Area Modifiers with Exclude operation. An added object in the Add Modifier's list will generate projected area of exclusion. More information and examples can be found here: Area Modifiers Rollout.
      Kind regards,
      Ivelina
      Ivelina Mincheva
      V-Ray for SketchUp | V-Ray for Rhino | QA
      www.chaos.com
        Kind regards,
        Ivelina
        Thanks I'm waiting for the new version in the meantime but I'll try the solution you suggested I would like to know how I can create a completely transparent object to be able to include scatter inside in practice I tried to create a transparent material but at the point of contact it still creates a trace
          A simple solution for no artifacts/traces is avoiding the overlapping faces that causes them. The good thing is that the Area modifiers uses the projection of the added object, so the actual object can be below or above the Scatter's host surface. Then a transparent material can be used for the area modifier's object.
          Example:
          Additionally, the Falloff Near and Far options can be used to adjust the distance of a gradual fading effect from the area modifier object and to achieve better or more interesting results.
          Example:
          Click image for larger version  Name:	Falloff_Near_effect-example.png Views:	0 Size:	844.6 KB ID:	1213116
          Let me know if this information helps.
          If you have more questions, do not hesitate to ask.
          Regards,
          Ivelina
          Ivelina Mincheva
          www.chaos.com
            Example:
            Example:
            Regards,
            Ivelina
            Thanks, you have been really helpful. Now I ask you, if I want the exclusion objects to be transparent, what material should I match them with? Because any transparency I create, they can be seen anyway. I attach transparent material.
              Thank you!
              Your transparent material looks good to me. As long as there are no overlapping faces between the transparent object's geometry and other faces, it should work fine. A good practice is to use 3D objects instead of just surfaces. You can also try to add an attribute "Raytrace Properties" to a material and make it invisible with disabling the options: Visible to Camera, Visible in Reflections, Visible in Refractions and Cast Shadows.
              Example:
              If you still have issues with transparency objects, you can send a test scene using the pack project option (V-Ray>Pack Project...) through our support portal (https://support.chaos.com/hc/en-us/requests/new) with the link from this forum topic in the message, so we can investigate it.
              Regards,
              Ivelina​​
              Ivelina Mincheva
              www.chaos.com
                Thank you!
                Example:
                Regards,
                Ivelina​​
                Thanks, you were quick and explanatory, congratulations
