Animated Textures not Looping
  • Animated Textures not Looping
    Hi Chaos Team
    Is there a way to get animated textures to loop properly?
    I am trying to get the water texture im using as a displacement map to loop for an animation (for use with Chaos Vantage) but I cannot get the frames to loop? I asked on the Vantage forum and was directed here to ask is there is a workaround?
    I have also tried using ifl sequence files from Figment but again it will not loop the sequence.
    Hoping this can be fixed on the upcoming Vray 7 release if there is not already a way to achieve this. Any word on its release date/month?
    Thanks N
    Hello NRH1981 ,
    Thank you for posting this.
    We have created an article that explains how to set up your image sequence. Our documentation also provides more information on how this feature works.
    If you set up everything correctly by following the steps from the article, but the Image Sequence doesn't start, please turn off this option and try rendering a couple of frames to see if it will start. If that's the case, please keep in mind that we are aware of this issue, and it's logged in our internal system as WEBUI-7090.
    Rossen Rangelov | chaos.com
