Vray altering custom render output
  • Vray altering custom render output
    Hi guys, I need to render all my images at 3800 x 2133. If I change the custom output to these specs (which all my files are) If I close and re-open the file and render, the ratio instantly reverts to 3799 x 2133. So basically if I forget to go back into setting prior to re-rendering a saved file it dops one pixel. This is not a massive problem, just a niggle when it comes to post production. Would anyone know why this may be happening?
    Thanks in advance,
    Nick
    Hello AMG445,
    Thank you for bringing this issue to our attention. Please note that it is logged internally under WEBUI-7014 and I have linked your forum post to it, so you will be notified if there is a change.
    For the meantime please consider using the default 16:9 aspect ratio, in this case you will get 3800 x 2138 resolution and it will not be altered after the restart.
    Natalia Gruzdova | chaos.com
      No problem at all - thanks for the reply, Cheers, Nick
