Laubwerk Plants Vray 7 Sketchup
  • Laubwerk Plants Vray 7 Sketchup
    Greetings,
    Is there any action on behalf of Chaosgroup to be taken on the Laubwerk Plant texture issue as described in the link below?
    https://forums.sketchup.com/t/laubwe...extures/309966
    thank you in advance
    Hello ARTCH,
    Currently Laubwerk are working on adding support for V-Ray 7. Please refer to my colleague's post in this thread.
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
      Thank you very much.
      Regards
      Update…
      Is there any news on the progress of Laubwerk plants' compatibility with Vray 7?
      Unfortunately it is very difficult to find any information on the web about the new version, which according to the information here was supposed to be available within a few.... weeks.
      I would be very grateful for any information.
      I believe I am not the only one.
      Thank you in advance and best regards.​
        You are definitely not the only one, having this issue as well... for weeks!
          The same Laubwerk Plants models work well in Rhino 8 and Vray 7. Within SU 2024/2025 with Vray 7.001/7.002 they do not.
          Globe Plants issue as well:
          https://forums.sketchup.com/t/sketch...uares/316533/6
            Hi everybody,
            We have just released V-Ray 7, hotfix 3 for SketchUp - addressing the described problem.
            Note that if you have already saved a project using V-Ray 7, the Lubwerk assets will remain gray.
            If, however, you perform a Laubwerk import in the new version, the asset should render as expected.
            Regards,
            Konstantin
