unwanted transparency background
  • unwanted transparency background
    how to avoid transparent background in sketchup 24, vray 6 ? environment is checked but my render has still a transparent background.
    Png output is transparent, environment doesn't affect background in png output, you can try saving other format or using dome light..
      You can also use the No Alpha option:
        thanks that was the issue
          Note that even if you have already saved a PNG with transparency, it can be disabled in Photoshop.
          1. Open the image in PS
          2. Use Layer / Layer Mask / From Transparency menu option
          3. Delete the mask which appears in the layers stack without applying it
          4. The original background will reappear
